주요 콘텐츠로 건너뛰기
Samsung Impression LCD Flex Cable Replacement
필요한 것
  1. Samsung Impression LCD Flex Cable Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression LCD Flex Cable Replacement: 2 단계, 이미지 2개 중 1개 Samsung Impression LCD Flex Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression LCD Flex Cable Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression LCD Flex Cable Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression LCD Flex Cable Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  6. Samsung Impression LCD Flex Cable Replacement: 6 단계, 이미지 2개 중 1개 Samsung Impression LCD Flex Cable Replacement: 6 단계, 이미지 2개 중 2개
    • Gently tug the black and blue ribbon upwards to release the circuit board.
  7. Samsung Impression LCD Flex Cable Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
  8. Samsung Impression LCD Flex Cable Replacement: 8 단계, 이미지 2개 중 1개 Samsung Impression LCD Flex Cable Replacement: 8 단계, 이미지 2개 중 2개
    • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
    • The keys will peel right out of the screen side of the phone.
  9. Samsung Impression LCD Flex Cable Replacement: 9 단계, 이미지 1개 중 1개
    • The silver piece you are left with is the physical keyboard assembly.
  10. Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: 10 단계, 이미지 2개 중 1개 Samsung Impression LCD Flex Cable Replacement, LCD Flex Cable: 10 단계, 이미지 2개 중 2개
    • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
    • The keyboard slider frame will come off and the flex cable exposed, but not free.
  11. Samsung Impression LCD Flex Cable Replacement: 11 단계, 이미지 1개 중 1개
    • Remove 4 outer screws.
    • The screws are 3.5mm in length.
  12. Samsung Impression LCD Flex Cable Replacement: 12 단계, 이미지 3개 중 1개 Samsung Impression LCD Flex Cable Replacement: 12 단계, 이미지 3개 중 2개 Samsung Impression LCD Flex Cable Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the phone apart, and remove a 5th screw (3.5 mm).
    • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
    • The device will now be in two pieces
  13. Samsung Impression LCD Flex Cable Replacement: 13 단계, 이미지 2개 중 1개 Samsung Impression LCD Flex Cable Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the tab underneath the blue tape and gently pull the flex cable.
    • The flex cable will now be completely free.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Saul Villatoro
회원 가입일: 04/25/11
255 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2011 Cal Poly, Team 8-10, Regan Spring 2011 회원
CPSU-REGAN-S11S8G10
4 회원들
안내서 22개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 7,454
