주요 콘텐츠로 건너뛰기
Samsung Instinct Back Case Replacement
필요한 것
  1. Samsung Instinct Back Case Replacement, Battery: 1 단계, 이미지 1/1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Back Case Replacement: 2 단계, 이미지 1/1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Back Case Replacement, Back Case: 3 단계, 이미지 1/1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Back Case Replacement: 4 단계, 이미지 1/2 Samsung Instinct Back Case Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Back Case Replacement: 5 단계, 이미지 1/1
    • Lift the casing off of the phone.
결론
Jacob Michener
회원 가입일: 10/10/11
31 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 854
