주요 콘텐츠로 건너뛰기
Samsung Instinct Front Case Replacement
필요한 것
  1. Samsung Instinct Front Case Replacement, Battery: 1 단계, 이미지 1/1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Front Case Replacement: 2 단계, 이미지 1/1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Front Case Replacement, Back Case: 3 단계, 이미지 1/1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Front Case Replacement: 4 단계, 이미지 1/2 Samsung Instinct Front Case Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Front Case Replacement: 5 단계, 이미지 1/1
    • Lift the casing off of the phone.
  6. Samsung Instinct Front Case Replacement, Antenna: 6 단계, 이미지 1/1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Front Case Replacement: 7 단계, 이미지 1/1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Front Case Replacement: 8 단계, 이미지 1/1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Front Case Replacement: 9 단계, 이미지 1/1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Front Case Replacement, Front Case: 10 단계, 이미지 1/1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Front Case Replacement: 11 단계, 이미지 1/3 Samsung Instinct Front Case Replacement: 11 단계, 이미지 2/3 Samsung Instinct Front Case Replacement: 11 단계, 이미지 3/3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Front Case Replacement: 12 단계, 이미지 1/1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Front Case Replacement: 13 단계, 이미지 1/2 Samsung Instinct Front Case Replacement: 13 단계, 이미지 2/2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Front Case Replacement: 14 단계, 이미지 1/1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Front Case Replacement: 15 단계, 이미지 1/1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
결론
Jacob Michener
회원 가입일: 10/10/11
31 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 736
