주요 콘텐츠로 건너뛰기
Samsung Instinct Motherboard Replacement
필요한 것
  1. Samsung Instinct Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Motherboard Replacement, Back Case: 3 단계, 이미지 1개 중 1개
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Samsung Instinct Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the casing off of the phone.
  6. Samsung Instinct Motherboard Replacement, Antenna: 6 단계, 이미지 1개 중 1개
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Motherboard Replacement, Front Case: 10 단계, 이미지 1개 중 1개
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Samsung Instinct Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Samsung Instinct Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Samsung Instinct Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 1개 Samsung Instinct Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 2개 Samsung Instinct Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 3개
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
  17. Samsung Instinct Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
  18. Samsung Instinct Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
  19. Samsung Instinct Motherboard Replacement: 19 단계, 이미지 1개 중 1개
    • Gently lift the motherboard from the center frame.
결론
작성자
5다른 기여자 명과 함께
Brayton
회원 가입일: 10/12/11
49 평판
안내서 2개를 작성함
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 5,179
