주요 콘텐츠로 건너뛰기
Samsung Instinct Speaker Replacement
필요한 것
  1. Samsung Instinct Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Speaker Replacement, Back Case: 3 단계, 이미지 1개 중 1개
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Speaker Replacement: 4 단계, 이미지 2개 중 1개 Samsung Instinct Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the casing off of the phone.
  6. Samsung Instinct Speaker Replacement, Antenna: 6 단계, 이미지 1개 중 1개
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Speaker Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Speaker Replacement, Front Case: 10 단계, 이미지 1개 중 1개
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 1개 Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 2개 Samsung Instinct Speaker Replacement: 11 단계, 이미지 3개 중 3개
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Speaker Replacement: 12 단계, 이미지 1개 중 1개
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Speaker Replacement: 13 단계, 이미지 2개 중 1개 Samsung Instinct Speaker Replacement: 13 단계, 이미지 2개 중 2개
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Speaker Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Speaker Replacement: 15 단계, 이미지 1개 중 1개
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Speaker Replacement, Speaker: 16 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers to grasp the pins of the speaker, gently lift the speaker up out of its setting in the front case.
결론
작성자
5다른 기여자 명과 함께
Brayton
회원 가입일: 10/12/11
49 평판
안내서 2개를 작성함
Cal Poly, Team 3-13, Regan Fall 2011 Cal Poly, Team 3-13, Regan Fall 2011 회원
CPSU-REGAN-F11S3G13
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 880
