주요 콘텐츠로 건너뛰기
Samsung Jack Antenna Replacement
필요한 것
  1. Samsung Jack Antenna Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Antenna Replacement: 2 단계, 이미지 1/1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Antenna Replacement, Rear Case: 3 단계, 이미지 1/1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Antenna Replacement: 4 단계, 이미지 1/3 Samsung Jack Antenna Replacement: 4 단계, 이미지 2/3 Samsung Jack Antenna Replacement: 4 단계, 이미지 3/3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Antenna Replacement: 5 단계, 이미지 1/1
    • Lift the rear case off of the phone.
  6. Samsung Jack Antenna Replacement, Antenna: 6 단계, 이미지 1/1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Antenna Replacement: 7 단계, 이미지 1/3 Samsung Jack Antenna Replacement: 7 단계, 이미지 2/3 Samsung Jack Antenna Replacement: 7 단계, 이미지 3/3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
결론
Paul Piller
회원 가입일: 04/12/11
56 평판
안내서 5개 작성하였습니다
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G57
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 2,339
