주요 콘텐츠로 건너뛰기
Samsung Jack Keyboard Replacement
필요한 것
  1. Samsung Jack Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Keyboard Replacement: 2 단계, 이미지 1/1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Keyboard Replacement, Rear Case: 3 단계, 이미지 1/1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Keyboard Replacement: 4 단계, 이미지 1/3 Samsung Jack Keyboard Replacement: 4 단계, 이미지 2/3 Samsung Jack Keyboard Replacement: 4 단계, 이미지 3/3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Keyboard Replacement: 5 단계, 이미지 1/1
    • Lift the rear case off of the phone.
  6. Samsung Jack Keyboard Replacement, Antenna: 6 단계, 이미지 1/1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Keyboard Replacement: 7 단계, 이미지 1/3 Samsung Jack Keyboard Replacement: 7 단계, 이미지 2/3 Samsung Jack Keyboard Replacement: 7 단계, 이미지 3/3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
  8. Samsung Jack Keyboard Replacement, Speaker: 8 단계, 이미지 1/1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  9. Samsung Jack Keyboard Replacement: 9 단계, 이미지 1/2 Samsung Jack Keyboard Replacement: 9 단계, 이미지 2/2
    • Use the spudger to detach the speaker ribbon cable.
  10. Samsung Jack Keyboard Replacement: 10 단계, 이미지 1/1
    • Lift the speaker out of its compartment.
  11. Samsung Jack Keyboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove the power and volume buttons on the right side of the Motherboard.
  12. Samsung Jack Keyboard Replacement: 12 단계, 이미지 1/2 Samsung Jack Keyboard Replacement: 12 단계, 이미지 2/2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  13. Samsung Jack Keyboard Replacement: 13 단계, 이미지 1/2 Samsung Jack Keyboard Replacement: 13 단계, 이미지 2/2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  14. Samsung Jack Keyboard Replacement: 14 단계, 이미지 1/3 Samsung Jack Keyboard Replacement: 14 단계, 이미지 2/3 Samsung Jack Keyboard Replacement: 14 단계, 이미지 3/3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  15. Samsung Jack Keyboard Replacement: 15 단계, 이미지 1/2 Samsung Jack Keyboard Replacement: 15 단계, 이미지 2/2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  16. Samsung Jack Keyboard Replacement: 16 단계, 이미지 1/1
    • Lift the Motherboard off of the phone.
  17. Samsung Jack Keyboard Replacement, Keyboard: 17 단계, 이미지 1/3 Samsung Jack Keyboard Replacement, Keyboard: 17 단계, 이미지 2/3 Samsung Jack Keyboard Replacement, Keyboard: 17 단계, 이미지 3/3
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
  18. Samsung Jack Keyboard Replacement: 18 단계, 이미지 1/2 Samsung Jack Keyboard Replacement: 18 단계, 이미지 2/2
    • Lift up the LCD frame.
  19. Samsung Jack Keyboard Replacement: 19 단계, 이미지 1/3 Samsung Jack Keyboard Replacement: 19 단계, 이미지 2/3 Samsung Jack Keyboard Replacement: 19 단계, 이미지 3/3
    • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
    • The keyboard and directional keys are glued separately to the LCD frame.
    • Insert the spudger between the keyboard and the frame.
    • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
  20. Samsung Jack Keyboard Replacement: 20 단계, 이미지 1/3 Samsung Jack Keyboard Replacement: 20 단계, 이미지 2/3 Samsung Jack Keyboard Replacement: 20 단계, 이미지 3/3
    • Insert the spudger between the directional keys and the frame.
    • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jaime Serrano
회원 가입일: 04/11/11
59 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G57
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,076
