이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Grasp the bottom left and right corners of the battery and lift it from its housing.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Insert the Plastic Opening Tool in between the front and rear cases.
Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Remove the power and volume buttons on the right side of the Motherboard.
Use a spudger to detach the camera ribbon cable.
Lift the camera off of the Motherboard.
Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
Use a spudger to disconnect the Motherboard ribbon cable.
Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
Insert the spudger between the keyboard and the frame.
Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
Insert the spudger between the directional keys and the frame.
Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
다른 한 분이 해당 안내서를 완성하였습니다.
