소개
Use this repair guide to replace the Motherboard.
필요한 것
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
거의 끝나갑니다!
결론
