주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Samsung Jack Speaker Replacement
필요한 것
  1. Samsung Jack Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: 2 단계, 이미지 1/1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: 3 단계, 이미지 1/1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: 4 단계, 이미지 1/3 Samsung Jack Speaker Replacement: 4 단계, 이미지 2/3 Samsung Jack Speaker Replacement: 4 단계, 이미지 3/3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: 5 단계, 이미지 1/1
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: 7 단계, 이미지 1/2 Samsung Jack Speaker Replacement: 7 단계, 이미지 2/2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: 8 단계, 이미지 1/1
    • Lift the speaker out of its compartment.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paul Piller
회원 가입일: 04/12/11
56 평판
안내서 5개 작성하였습니다
Cal Poly, Team 24-57, Amido Spring 2011 Cal Poly, Team 24-57, Amido Spring 2011 회원
CPSU-AMIDO-S11S24G57
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,726
