주요 콘텐츠로 건너뛰기
Samsung Juke Motherboard Replacement
필요한 것
  1. Samsung Juke Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Juke Motherboard Replacement: 2 단계, 이미지 2/2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Motherboard Replacement, Camera/Speaker: 3 단계, 이미지 1/1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Motherboard Replacement: 5 단계, 이미지 1/3 Samsung Juke Motherboard Replacement: 5 단계, 이미지 2/3 Samsung Juke Motherboard Replacement: 5 단계, 이미지 3/3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Juke Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Juke Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Samsung Juke Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke Motherboard Replacement: 10 단계, 이미지 1/2 Samsung Juke Motherboard Replacement: 10 단계, 이미지 2/2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke Motherboard Replacement: 11 단계, 이미지 1/3 Samsung Juke Motherboard Replacement: 11 단계, 이미지 2/3 Samsung Juke Motherboard Replacement: 11 단계, 이미지 3/3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Renee Kuzniar
회원 가입일: 04/13/10
82 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-18, Maness Spring 2010 Cal Poly, Team 6-18, Maness Spring 2010 회원
CPSU-MANESS-S10S6G18
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 2,935
