주요 콘텐츠로 건너뛰기
Samsung L100 LCD Screen Replacement
필요한 것
  1. Samsung L100 LCD Screen Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 1개 Samsung L100 LCD Screen Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 2개 Samsung L100 LCD Screen Replacement, Removing Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Samsung L100 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 LCD Screen Replacement: 3 단계, 이미지 3개 중 1개 Samsung L100 LCD Screen Replacement: 3 단계, 이미지 3개 중 2개 Samsung L100 LCD Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 2개 중 1개 Samsung L100 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 2개 중 2개
    • Remove the screws holding the circuit board.
    • Carefully remove the circuit board.
  7. Samsung L100 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Samsung L100 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully lift circuit board from camera.
    • Circuit board still attached to camera by ribbon.
  8. Samsung L100 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the front cover. It should come off easily.
    • Buttons might fall out when you remove the front cover.
  9. Samsung L100 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Samsung L100 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the green tape that holds the LCD screen.
    • Carefully lift the LCD Screen.
  10. Samsung L100 LCD Screen Replacement: 10 단계, 이미지 3개 중 1개 Samsung L100 LCD Screen Replacement: 10 단계, 이미지 3개 중 2개 Samsung L100 LCD Screen Replacement: 10 단계, 이미지 3개 중 3개
    • Flip the camera over to the other side.
    • Lift the black strip and the ribbon should easily come out.
    • The LCD Screen should be completely separated from the camera now.
  11. Samsung L100 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Samsung L100 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Insert the new LCD Screen by pushing the ribbon into the slot.
    • Flip the black strip back down to lock the ribbon in.
    • Your new LCD Screen should be connected to the camera now.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hasit
회원 가입일: 04/15/10
207 평판
안내서 2개를 작성함
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 회원
CPSU-MANESS-S10S6G17
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 6,356
