주요 콘텐츠로 건너뛰기
Samsung L100 camera lens replacement
필요한 것
  1. Samsung L100 camera lens replacement, Removing Back Cover: 1 단계, 이미지 1/3 Samsung L100 camera lens replacement, Removing Back Cover: 1 단계, 이미지 2/3 Samsung L100 camera lens replacement, Removing Back Cover: 1 단계, 이미지 3/3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 camera lens replacement: 2 단계, 이미지 1/2 Samsung L100 camera lens replacement: 2 단계, 이미지 2/2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 camera lens replacement: 3 단계, 이미지 1/3 Samsung L100 camera lens replacement: 3 단계, 이미지 2/3 Samsung L100 camera lens replacement: 3 단계, 이미지 3/3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 camera lens replacement: 4 단계, 이미지 1/1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 camera lens replacement: 5 단계, 이미지 1/1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 camera lens replacement, Camera Lens: 6 단계, 이미지 1/1
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  7. Samsung L100 camera lens replacement: 7 단계, 이미지 1/1
    • Remove green tape from ribbon.
  8. Samsung L100 camera lens replacement: 8 단계, 이미지 1/2 Samsung L100 camera lens replacement: 8 단계, 이미지 2/2
    • Remove four screws around lens.
  9. Samsung L100 camera lens replacement: 9 단계, 이미지 1/1
    • Use spudger to remove ribbon connecting the circuit board from lens.
  10. Samsung L100 camera lens replacement: 10 단계, 이미지 1/1
    • Remove lens from camera.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Adriel
회원 가입일: 04/15/10
123 평판
안내서 2개 작성하였습니다
Cal Poly, Team 6-17, Maness Spring 2010 Cal Poly, Team 6-17, Maness Spring 2010 회원
CPSU-MANESS-S10S6G17
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 25
전체 시간: 9,992
