주요 콘텐츠로 건너뛰기
Samsung LE40 LED TV Cooling fan Replacement
  1. Samsung LE40 LED TV Cooling fan Replacement, Cooling fan: 1 단계, 이미지 2개 중 1개 Samsung LE40 LED TV Cooling fan Replacement, Cooling fan: 1 단계, 이미지 2개 중 2개
    • Remove 19 screws around edges and one more centrally located. Remove TV Back panel.
    • Be careful with the very small screw located near the PC card dock / HDMI In 4
  2. Samsung LE40 LED TV Cooling fan Replacement: 2 단계, 이미지 1개 중 1개
    • Above main PCB you'll see the cooling fan, much like a PC fan. Here it is shown with no retaining screws and wiring.
  3. Samsung LE40 LED TV Cooling fan Replacement: 3 단계, 이미지 1개 중 1개
    • With the fan removed you can find the Part Number on the reverse side.
    • Googling this number gave me 2 options, a £45 replacement or a £10 one from Ebay.
    • As you can see, the fan casing is slightly special as it is open on one side and the edges of the casing are slightly curved.
    • What I didn't know is what my Ebay buy would look like, despite it being sold with identical Part Number the Suffix was different.
  4. Samsung LE40 LED TV Cooling fan Replacement: 4 단계, 이미지 1개 중 1개
  5. Samsung LE40 LED TV Cooling fan Replacement: 5 단계, 이미지 1개 중 1개
    • Here is the fan that I received. Apologies , I took the photo after I had carved it up.
  6. Samsung LE40 LED TV Cooling fan Replacement: 6 단계, 이미지 1개 중 1개
    • Use a oscillating multi tool or small rotary cutting tool to remove the casing that is not required.
  7. Samsung LE40 LED TV Cooling fan Replacement: 7 단계, 이미지 1개 중 1개
    • Apply some heat to the sides of the casing using heat gun or lighter. This will allow you to bend the sides of the casing slightly to recreate the casing of the original.
  8. Samsung LE40 LED TV Cooling fan Replacement: 8 단계, 이미지 1개 중 1개
    • Note on the original fan the retaining screw locations are recessed to allow it to locate on threaded posts.
  9. Samsung LE40 LED TV Cooling fan Replacement: 9 단계, 이미지 1개 중 1개
    • Use an 8.5mm drill bit to create recesses on new fan casing
  10. Samsung LE40 LED TV Cooling fan Replacement: 10 단계, 이미지 1개 중 1개
    • Original screws (bottom) were not long enough to use on the new fan. I found some suitable screws (top) from some kitchen cupboard catches.
  11. Samsung LE40 LED TV Cooling fan Replacement: 11 단계, 이미지 1개 중 1개
    • New fan installed.
    • Note wiring on new fan was not long enough so I had to use the wiring from the original fan and solder on to the new wires after cutting connector off.
  12. Samsung LE40 LED TV Cooling fan Replacement: 12 단계, 이미지 2개 중 1개 Samsung LE40 LED TV Cooling fan Replacement: 12 단계, 이미지 2개 중 2개
    • Refit TV back panel
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ben
회원 가입일: 11/27/19
235 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 66
전체 시간: 6,107
