주요 콘텐츠로 건너뛰기
Samsung LN-T5265F Rear Case Replacement
필요한 것
  1. Samsung LN-T5265F Rear Case Replacement, Stand: 1 단계, 이미지 1/1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F Rear Case Replacement, Rear Case: 3 단계, 이미지 1/2 Samsung LN-T5265F Rear Case Replacement, Rear Case: 3 단계, 이미지 2/2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Steven Carlton
회원 가입일: 08/19/13
606 평판
안내서 3개 작성하였습니다
댓글 한 개
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 2,400
