주요 콘텐츠로 건너뛰기
Samsung LN-T5265F T-Con Board Replacement
필요한 것
  1. Samsung LN-T5265F T-Con Board Replacement, Stand: 1 단계, 이미지 1/1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F T-Con Board Replacement, Rear Case: 3 단계, 이미지 1/2 Samsung LN-T5265F T-Con Board Replacement, Rear Case: 3 단계, 이미지 2/2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
  3. Samsung LN-T5265F T-Con Board Replacement, T-Con Board: 4 단계, 이미지 1/2 Samsung LN-T5265F T-Con Board Replacement, T-Con Board: 4 단계, 이미지 2/2
    • The Timing Controller (T-Con) board is located at the top center behind a metal shield.
    • Remove four Phillips screws.
    • Tilt the metal shield towards the top of the TV and lift away.
  4. Samsung LN-T5265F T-Con Board Replacement: 5 단계, 이미지 1/1
    • Disconnect the two ribbon cables at the top by flipping up the retaining flaps and sliding the ribbons straight up towards the top of the TV.
  5. Samsung LN-T5265F T-Con Board Replacement: 6 단계, 이미지 1/1
    • Disconnect the bottom ribbon cable by depressing the two buttons on either side of the connector and sliding down towards the bottom of the TV.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Steven Carlton
회원 가입일: 08/19/13
606 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 10,071
