주요 콘텐츠로 건너뛰기
Samsung ML2510 Motor Replacement
필요한 것
  1. Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Motor Replacement: 3 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement: 3 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement: 3 단계, 이미지 3개 중 3개
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Motor Replacement, Motor: 4 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement, Motor: 4 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement, Motor: 4 단계, 이미지 3개 중 3개
    • Remove the front panel by gently moving the holes on the panel, one at a time, from the pegs attached to the main body of the printer.
  5. Samsung ML2510 Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the two, 1", Phillips, PH#2 screws on the front face of the printer.
  6. Samsung ML2510 Motor Replacement: 6 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement: 6 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Use plastic opening tool to gently lift one side of the top panel from its peg.
    • Repeat the first process for the other side.
    • Lift the top panel from the front of the printer to remove it entirely.
  7. Samsung ML2510 Motor Replacement: 7 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement: 7 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement: 7 단계, 이미지 3개 중 3개
    • Lift the left side panel up from the raised stops.
    • Gently rotate the panel, as indicated in the picture, to remove the panel entirely.
  8. Samsung ML2510 Motor Replacement: 8 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement: 8 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Use Phillips #2 screwdriver to remove the five, 1", Phillips, PH#2 screws on the side metal panel.
    • Remove the two, 1", Phillips, PH#2 screws on the back of the printer.
    • Flip over the metal panel to reveal the gear mechanism.
  9. Samsung ML2510 Motor Replacement: 9 단계, 이미지 3개 중 1개 Samsung ML2510 Motor Replacement: 9 단계, 이미지 3개 중 2개 Samsung ML2510 Motor Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the cable attached to the motor.
    • The entire panel can be removed from the rest of the printer.
    • Use a Phillips #2 screwdriver to remove the motor from the panel by removing the two, 1", Phillips, PH#2 screws.
    • Replace the motor and reassemble the printer by following the instructions in reverse order.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개를 작성함
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 14
전체 시간: 4,973
