주요 콘텐츠로 건너뛰기
Samsung ML2510 Power Button Replacement
필요한 것
  1. Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 1개 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 2개 Samsung ML2510 Power Button Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Power Button Replacement: 3 단계, 이미지 3개 중 1개 Samsung ML2510 Power Button Replacement: 3 단계, 이미지 3개 중 2개 Samsung ML2510 Power Button Replacement: 3 단계, 이미지 3개 중 3개
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Power Button Replacement, Power Button: 4 단계, 이미지 3개 중 1개 Samsung ML2510 Power Button Replacement, Power Button: 4 단계, 이미지 3개 중 2개 Samsung ML2510 Power Button Replacement, Power Button: 4 단계, 이미지 3개 중 3개
    • Remove the front panel by gently separating the holes on the panel from the pegs attached to the main printer body.
  5. Samsung ML2510 Power Button Replacement: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove both 1" screws on the front face of the printer.
  6. Samsung ML2510 Power Button Replacement: 6 단계, 이미지 3개 중 1개 Samsung ML2510 Power Button Replacement: 6 단계, 이미지 3개 중 2개 Samsung ML2510 Power Button Replacement: 6 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat the last step to free the opposite side of the top panel.
    • Lift the top panel from the front to remove it entirely.
    • Turn over the top panel to reveal the button on the underside of the panel.
  7. Samsung ML2510 Power Button Replacement: 7 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove both 1" screws that secure the button to the underside of the top panel.
  8. Samsung ML2510 Power Button Replacement: 8 단계, 이미지 2개 중 1개 Samsung ML2510 Power Button Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the clear plastic piece and the orange button from the panel.
    • Remove the orange button and the spring from the clear plastic holder.
    • Replace the button and reassemble the printer following the directions in reverse order.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개를 작성함
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 3,341
