주요 콘텐츠로 건너뛰기
Samsung ML2510 Side Cooling Fan Replacement
필요한 것
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 1/3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 2/3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: 1 단계, 이미지 3/3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 1/3 Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 2/3 Samsung ML2510 Side Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 1/3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 2/3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: 4 단계, 이미지 3/3
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 1/3 Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 2/3 Samsung ML2510 Side Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 1/3 Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 2/3 Samsung ML2510 Side Cooling Fan Replacement: 7 단계, 이미지 3/3
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: 8 단계, 이미지 1/1
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: 9 단계, 이미지 1/1
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
결론
다른 2명이 해당 안내서를 완성하였습니다.
bbaustin
회원 가입일: 10/12/11
268 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-18, Regan Fall 2011 Cal Poly, Team 17-18, Regan Fall 2011 회원
CPSU-REGAN-F11S17G18
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 9
전체 시간: 2,546
