주요 콘텐츠로 건너뛰기
Samsung MV900F Lens Assembly Replacement
필요한 것
  1. Samsung MV900F Lens Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Lens Assembly Replacement: 2 단계, 이미지 1/1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Lens Assembly Replacement: 3 단계, 이미지 1/1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Lens Assembly Replacement, Screen: 4 단계, 이미지 1/2 Samsung MV900F Lens Assembly Replacement, Screen: 4 단계, 이미지 2/2
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Lens Assembly Replacement: 5 단계, 이미지 1/2 Samsung MV900F Lens Assembly Replacement: 5 단계, 이미지 2/2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Lens Assembly Replacement: 6 단계, 이미지 1/1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Lens Assembly Replacement: 8 단계, 이미지 1/1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Lens Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the old screen.
  10. Samsung MV900F Lens Assembly Replacement, Lens Assembly: 10 단계, 이미지 1/1
    • Remove the 2.381 mm screw with a Phillips #00 screwdriver.
  11. Samsung MV900F Lens Assembly Replacement: 11 단계, 이미지 1/1
    • Use the plastic opening tool to remove the silver metal lens cover.
  12. Samsung MV900F Lens Assembly Replacement: 12 단계, 이미지 1/1
    • Use the tweezers to remove the black electrical tape covering the copper connector to the control board.
  13. Samsung MV900F Lens Assembly Replacement: 13 단계, 이미지 1/1
    • From the front of the camera, push the lens through the back of the camer.a
  14. Samsung MV900F Lens Assembly Replacement: 14 단계, 이미지 1/2 Samsung MV900F Lens Assembly Replacement: 14 단계, 이미지 2/2
    • Use a pair of tweezers to flip up the black retaining bar on each of the two ZIF connectors.
  15. Samsung MV900F Lens Assembly Replacement: 15 단계, 이미지 1/2 Samsung MV900F Lens Assembly Replacement: 15 단계, 이미지 2/2
    • Remove the lens assembly from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ethan Rowland
회원 가입일: 03/03/15
216 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 13-2, Blackburne Winter 2015 Sam Houston State, Team 13-2, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 744
