주요 콘텐츠로 건너뛰기
Samsung MV900F Screen Replacement
필요한 것
  1. Samsung MV900F Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the lock towards the middle of the camera, in the same direction of the arrow.
  2. Samsung MV900F Screen Replacement: 2 단계, 이미지 1/1
    • Push the blue battery holder up in the direction of the arrow.
  3. Samsung MV900F Screen Replacement: 3 단계, 이미지 1/1
    • Pull the battery out of the battery slot.
  4. Samsung MV900F Screen Replacement, Screen: 4 단계, 이미지 1/2 Samsung MV900F Screen Replacement, Screen: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the four rubber screw covers.
  5. Samsung MV900F Screen Replacement: 5 단계, 이미지 1/2 Samsung MV900F Screen Replacement: 5 단계, 이미지 2/2
    • Remove the four Phillips 2.381 mm screws on back side of camera and one Phillips 2.381 mm screw on the bottom of the camera, using a Phillips #00 screwdriver.
  6. Samsung MV900F Screen Replacement: 6 단계, 이미지 1/1
    • Remove the back casing by just carefully pulling the casing off of the camera.
  7. Samsung MV900F Screen Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #00 screw driver to remove the four 2.381 mm screws next to the screen hinge.
  8. Samsung MV900F Screen Replacement: 8 단계, 이미지 1/1
    • Use plastic opening tool to disconnect screen connector from the control board.
  9. Samsung MV900F Screen Replacement: 9 단계, 이미지 1/1
    • Remove the old screen.
결론
To reassemble your device, follow these steps in reverse order.
Ethan Rowland
회원 가입일: 03/03/15
216 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 13-2, Blackburne Winter 2015 Sam Houston State, Team 13-2, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G2
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Anyone an Idea where I can buy a cheap new display for that cam?
Bernhard Prieler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 28
전체 시간: 863
