주요 콘텐츠로 건너뛰기
Samsung Moment Camera Button Replacement
필요한 것
  1. Samsung Moment Camera Button Replacement, Camera Button: 1 단계, 이미지 1/3 Samsung Moment Camera Button Replacement, Camera Button: 1 단계, 이미지 2/3 Samsung Moment Camera Button Replacement, Camera Button: 1 단계, 이미지 3/3
    • Power off the phone using the "Power Button", the circular middle button in the center of the phone.
    • Locate the camera button on bottom right side of your phone
    • Remove the back panel of the phone by sliding the spudger along the edge of the phone. The rear plastic panel will snap off from the remainder of the phone.
  2. Samsung Moment Camera Button Replacement: 2 단계, 이미지 1/1
    • Remove the battery from the phone by pulling up on the battery edge.
  3. Samsung Moment Camera Button Replacement: 3 단계, 이미지 1/1
    • If you have not already removed the memory card, remove it by gently sliding it out of its holder.
  4. Samsung Moment Camera Button Replacement: 4 단계, 이미지 1/3 Samsung Moment Camera Button Replacement: 4 단계, 이미지 2/3 Samsung Moment Camera Button Replacement: 4 단계, 이미지 3/3
    • Using the small Phillips #000 screw driver, remove the six screws from the back of the phone.
    • Using the spudger tool, separate the back housing from the phone.
    • While separating the back house from the phone, the three buttons (the volume, the speaker, and the camera button) might fall out. Be sure to keep track of these three buttons and use them for reassembly.
  5. Samsung Moment Camera Button Replacement: 5 단계, 이미지 1/2 Samsung Moment Camera Button Replacement: 5 단계, 이미지 2/2
    • If the camera button did not fall, carefully remove it using a pair of tweezers. At this point, you can replace the button with a new one.
결론
Be sure to gently slide the memory card back in its holder.
다른 3명이 해당 안내서를 완성하였습니다.
Allison Coffee
회원 가입일: 09/26/13
214 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 741
