주요 콘텐츠로 건너뛰기
Samsung Moment Camera Replacement
필요한 것
  1. Samsung Moment Camera Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the back cover off the back of the phone to reveal the battery.
  2. Samsung Moment Camera Replacement: 2 단계, 이미지 1/2 Samsung Moment Camera Replacement: 2 단계, 이미지 2/2
    • Place a finger in one or both of the indents by the bottom of the battery. Then pull out to remove the battery from the phone.
  3. Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: 3 단계, 이미지 1/2 Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: 3 단계, 이미지 2/2
    • Identify and remove the 6 screws on the rear case of the phone.
  4. Samsung Moment Camera Replacement: 4 단계, 이미지 1/2 Samsung Moment Camera Replacement: 4 단계, 이미지 2/2
    • Using a spudger, separate the rear case of the phone from the front case.
  5. Samsung Moment Camera Replacement, Camera: 5 단계, 이미지 1/1
    • Identify the phone's camera piece
  6. Samsung Moment Camera Replacement: 6 단계, 이미지 1/1
    • Use a spudger to peel back the green processing chip, exposing the wires underneath. Identify the thin golden band which connects the camera to the rest of the phone.
  7. Samsung Moment Camera Replacement: 7 단계, 이미지 1/1
    • Using the spudger, separate the golden band from its resting dock. It should come apart fairly easily, like undoing a bit of velcro. Once separated, the camera should slide out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Steven Cooney
회원 가입일: 03/07/16
200 평판
안내서 1개 작성함
Marist, Team 1-1, Laflen Spring 2016 Marist, Team 1-1, Laflen Spring 2016 회원
MARS-LAFLEN-S16S1G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 281
