이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the camera of the Samsung Mythic SGH-a897.
필요한 것
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Use a plastic opening tool to disconnect the camera cable from the motherboard.
Carefully remove the camera from the phone.
거의 끝나갑니다!
결론
