소개
Use this guide to replace the daughterboard in the Samsung Mythic SGH-a897.
부품
지정된 부품이 없습니다.
Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
Use a plastic opening tool to disconnect the camera cable from the motherboard.
Carefully remove the camera from the phone.
use the tweezers to unclip the connector as shown.
This is the only attachment that is holding the daughterboard to the motherboard. You can no remove the daughterboard.
거의 끝나갑니다!
결론
