이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the daughterboard in the Samsung Mythic SGH-a897.
필요한 것
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
Carefully remove the camera from the phone's motherboard.
use the tweezers to unclip the connector as shown.
This is the only attachment that is holding the daughterboard to the motherboard. You can no remove the daughterboard.
