소개
This guide will show you how to get access to the LCD screen in order to clean or replace it.
부품
지정된 부품이 없습니다.
Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
Use a plastic opening tool to disconnect the camera cable from the motherboard.
Carefully remove the camera from the phone.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
