주요 콘텐츠로 건너뛰기
Samsung Mythic SGH-a897 Rear Case Replacement
필요한 것
  1. Samsung Mythic SGH-a897 Rear Case Replacement, Battery: 1 단계, 이미지 1/1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Rear Case Replacement: 2 단계, 이미지 1/1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Rear Case Replacement, Rear Case: 3 단계, 이미지 1/1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Rear Case Replacement: 4 단계, 이미지 1/1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
결론
Morgan Yost
회원 가입일: 04/08/13
46 평판
안내서 6개 작성하였습니다
Cal Poly, Team 17-1, Regan Spring 2013 Cal Poly, Team 17-1, Regan Spring 2013 회원
CPSU-REGAN-S13S17G1
4 회원들
안내서 18개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 270
