이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Place your finger on either bottom corner of the battery slot and lift to remove the battery.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
Working along the seam, pry the back casing from the phone.
