이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to replace a faulty speaker.
필요한 것
To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
거의 끝나갑니다!
결론
