소개
This guide will show how to remove the back cover from the laptop in order to access the parts inside the computer.
This guide will be a pre-requisite guide for replacing the hard drive, and cooling fan.
필요한 것
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
거의 끝나갑니다!
결론
