주요 콘텐츠로 건너뛰기
Samsung NP N310 HAA2US Cooling Fan Replacement
필요한 것
  1. Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 1 단계, 이미지 1/3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 1 단계, 이미지 2/3 Samsung NP N310 HAA2US Cooling Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Make sure the laptop is powered off, and unplugged before removing the battery.
    • Slide the battery switch to the unlock symbol, and the battery will pop up.
    • Remove the battery.
  2. Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: 2 단계, 이미지 1/2 Samsung NP N310 HAA2US Cooling Fan Replacement, Back Panel: 2 단계, 이미지 2/2
    • Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
    • If there are rubber pads covering the screws, use a spudger to remove the rubber pads.
  3. Samsung NP N310 HAA2US Cooling Fan Replacement: 3 단계, 이미지 1/3 Samsung NP N310 HAA2US Cooling Fan Replacement: 3 단계, 이미지 2/3 Samsung NP N310 HAA2US Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool in the break between the back panel, and the keyboard.
    • Drag the opening tool around the edge to separate it.
    • Pull the back panel off of the laptop.
  4. Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 1/2 Samsung NP N310 HAA2US Cooling Fan Replacement, Cooling Fan: 4 단계, 이미지 2/2
    • Remove the 3 Phillips 4.5mm silver screws on the fan. Use a size 1 Phillips screwdriver
    • Remove the 1 Phillips 8mm black screw on the fan. Use a size 1 Phillips screwdriver.
  5. Samsung NP N310 HAA2US Cooling Fan Replacement: 5 단계, 이미지 1/2 Samsung NP N310 HAA2US Cooling Fan Replacement: 5 단계, 이미지 2/2
    • Lift the fan up, and remove the yellow tape.
    • Unplug the fan cable.
결론
Amir Afridi
회원 가입일: 09/29/16
626 평판
안내서 6개 작성하였습니다
USF Tampa, Team 4-1, Passmore Fall 2016 USF Tampa, Team 4-1, Passmore Fall 2016 회원
USFT-PASSMORE-F16S4G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 422
