소개
Replace or upgrade your Samsung NP N310 HAA2US hard drive with any compatible hard drive. A new hard drive can give a user more space and also provide better performance.
필요한 것
Slide the battery switch to the unlock symbol, and the battery will pop up.
Remove the battery.
Locate, and unscrew the 11 Phillips 8mm back cover screws, and 1 Phillips 5mm screw on the RAM cover. Use a #1 Philips screw driver to remove the screws.
Unscrew the 3 Phillips 3.5 mm screws. Use a size 1 Phillips screwdriver.
Lift the hardrive.
Pull the hard drive out.
