주요 콘텐츠로 건너뛰기
Samsung NP R580 JBB2 Hard drive Replacement
필요한 것
  1. Samsung NP R580 JBB2 Hard drive Replacement, Hard drive: 1 단계, 이미지 1/1
    • Power off laptop before starting.
    • Find the back plate cover labeled HDD.
  2. Samsung NP R580 JBB2 Hard drive Replacement: 2 단계, 이미지 1/2 Samsung NP R580 JBB2 Hard drive Replacement: 2 단계, 이미지 2/2
    • Remove both of the 5 mm Phillips head screws on the HDD back plate cover.
  3. Samsung NP R580 JBB2 Hard drive Replacement: 3 단계, 이미지 1/3 Samsung NP R580 JBB2 Hard drive Replacement: 3 단계, 이미지 2/3 Samsung NP R580 JBB2 Hard drive Replacement: 3 단계, 이미지 3/3
    • Pull down while applying pressure to release HDD back plate cover and then lift the cover upward.
  4. Samsung NP R580 JBB2 Hard drive Replacement: 4 단계, 이미지 1/1
    • Find the black plastic tab on the hard drive.
  5. Samsung NP R580 JBB2 Hard drive Replacement: 5 단계, 이미지 1/2 Samsung NP R580 JBB2 Hard drive Replacement: 5 단계, 이미지 2/2
    • Grasp the tab and pull it to the left until the hard drive releases its connection and is able to be lifted free.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brian Adamson
회원 가입일: 10/10/16
532 평판
안내서 3개 작성하였습니다
Texas Tech, Team 6-2, Bennett Fall 2016 Texas Tech, Team 6-2, Bennett Fall 2016 회원
TTU-BENNETT-F16S6G2
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 24
전체 시간: 1,880
