주요 콘텐츠로 건너뛰기
Samsung NP-N145-JP02US Fan Replacement
필요한 것
  1. Samsung NP-N145-JP02US Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Before starting the replacement, turn off the device sure and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Fan Replacement: 2 단계, 이미지 1/1
    • Remove the back of the device from the main frame by unscrewing the 14 4.5 mm screws using a Phillips #0 screwdriver.
    • Once all screws are out, pry open the back cover piece of the device using a plastic opening tool.
  3. Samsung NP-N145-JP02US Fan Replacement: 3 단계, 이미지 1/1
    • Remove the four 6.5 mm screws that surround the fan using the PH1 Phillips screwdriver head.
  4. Samsung NP-N145-JP02US Fan Replacement: 4 단계, 이미지 1/1
    • Manually remove the fan from the device by pulling out the connector.
결론
Kiarah Quarles
회원 가입일: 01/18/17
104 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 10
전체 시간: 591
