주요 콘텐츠로 건너뛰기
Samsung NP-N145-JP02US Keys Replacement
필요한 것
  1. Samsung NP-N145-JP02US Keys Replacement, Keys: 1 단계, 이미지 1/1
    • Before starting the replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Keys Replacement: 2 단계, 이미지 1/1
    • Open the device with the keyboard and screen showing.
  3. Samsung NP-N145-JP02US Keys Replacement: 3 단계, 이미지 1/1
    • Loosen the chosen key by prying all four corners with a plastic opening tool.
    • Push the plastic opening tool under the key and carefully pull upwards until the key comes loose and pops off.
  4. Samsung NP-N145-JP02US Keys Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Slowly grab the loose key away from the keyboard.
    • Be careful to leave the plastic pieces underneath the key in tact and unmoved. If plastic pieces do get moved, take tweezers and lift them back into place.
결론
Congratulations! You now have a keyboard with fully functional keys!
Laura Denali Harbinson
회원 가입일: 01/18/17
419 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 14
전체 시간: 332
