주요 콘텐츠로 건너뛰기
Samsung NP-N145-JP02US Screen Replacement
필요한 것
  1. Samsung NP-N145-JP02US Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Before starting replacement, turn off the device and disconnect all cords.
    • Close the device, lay it face down, and remove the battery.
  2. Samsung NP-N145-JP02US Screen Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the four black screw covers located at all corners of the screen with tweezers to expose the screws
    • Remove the four 4.5 mm screws located at each corner of the screen by using the Phillips #0 screwdriver.
  3. Samsung NP-N145-JP02US Screen Replacement: 3 단계, 이미지 1/1
    • Use a blue prying tool to pry the screen frame off.
    • Unscrew the four 6.5mm screws that are securing the screen using Phillips J0 screwdriver head.
  4. Samsung NP-N145-JP02US Screen Replacement: 4 단계, 이미지 1/3 Samsung NP-N145-JP02US Screen Replacement: 4 단계, 이미지 2/3 Samsung NP-N145-JP02US Screen Replacement: 4 단계, 이미지 3/3
    • Using your fingertips, gently pull screen to pop it out of the frame.
결론
Laura Denali Harbinson
회원 가입일: 01/18/17
419 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 15
전체 시간: 419
