주요 콘텐츠로 건너뛰기
Samsung NP-N210-JA02US Hard Drive Replacement
필요한 것
  1. Samsung NP-N210-JA02US Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Samsung NP-N210-JA02US Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Carefully slide both locking pins to the unlocked position.
  2. Samsung NP-N210-JA02US Hard Drive Replacement: 2 단계, 이미지 1/1
    • Slide the battery out of its housing.
  3. Samsung NP-N210-JA02US Hard Drive Replacement, Hard Drive Removal: 3 단계, 이미지 1/1
    • Remove the following 14 screws:
    • Thirteen 5 mm Phillips #1 screws
    • One 3.5 mm Philips #001 screw
  4. Samsung NP-N210-JA02US Hard Drive Replacement: 4 단계, 이미지 1/1
    • Carefully insert the plastic opening tool into the seam between the lower casing and the chrome bezel.
  5. Samsung NP-N210-JA02US Hard Drive Replacement: 5 단계, 이미지 1/1
    • Slide the opening tool across all sides of the lower case. Then, lift it up to remove the case and reveal the internal components.
  6. Samsung NP-N210-JA02US Hard Drive Replacement: 6 단계, 이미지 1/3 Samsung NP-N210-JA02US Hard Drive Replacement: 6 단계, 이미지 2/3 Samsung NP-N210-JA02US Hard Drive Replacement: 6 단계, 이미지 3/3
    • Carefully unplug the SATA connector from the hard drive.
  7. Samsung NP-N210-JA02US Hard Drive Replacement: 7 단계, 이미지 1/2 Samsung NP-N210-JA02US Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the four black 3.5 mm Philips #1 screws on the (side) of the hard drive.
  8. Samsung NP-N210-JA02US Hard Drive Replacement: 8 단계, 이미지 1/1
    • Gently lift the hard drive from its mounting bracket.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Afif Chehabaldeen
회원 가입일: 10/04/16
401 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Nance Fall 2016 USF Tampa, Team 1-3, Nance Fall 2016 회원
USFT-NANCE-F16S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 33
전체 시간: 3,553
