주요 콘텐츠로 건너뛰기
Samsung NP-NC10-KA02US Back Plate Replacement
필요한 것
  1. Samsung NP-NC10-KA02US Back Plate Replacement, Battery: 1 단계, 이미지 1/2 Samsung NP-NC10-KA02US Back Plate Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the external battery on the bottom side of the device.
    • Locate the tab on the right side of the battery.
    • Shift the tab to the left.
  2. Samsung NP-NC10-KA02US Back Plate Replacement: 2 단계, 이미지 1/1
    • Locate the tab on the left side of the device's battery.
    • Push the left tab to the right.
  3. Samsung NP-NC10-KA02US Back Plate Replacement: 3 단계, 이미지 1/1
    • Pull the battery up from the device.
  4. Samsung NP-NC10-KA02US Back Plate Replacement, Back Plate: 4 단계, 이미지 1/1
    • Locate the 14, 3.93 mm, screws that need to be removed on the base of the computer.
  5. Samsung NP-NC10-KA02US Back Plate Replacement: 5 단계, 이미지 1/1
    • Remove all 14 of the 3.93 mm screws using a PH1 screw bit.
  6. Samsung NP-NC10-KA02US Back Plate Replacement: 6 단계, 이미지 1/2 Samsung NP-NC10-KA02US Back Plate Replacement: 6 단계, 이미지 2/2
    • Using two plastic opening tools remove the back plate.
    • These plastic opening tools have a flat-head that extends as a wedge which are utilized to separate pressure fit plastic components without causing any damage to them.
    • The back plate is now removed exposing all of the hardware components.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Brian Smith
회원 가입일: 10/03/16
405 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Sullivan Fall 2016 USF Tampa, Team 1-1, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 401
