주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NP-QX411L Battery Replacement
필요한 것
  1. Samsung NP-QX411L Battery Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 Samsung NP-QX411L Battery Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
    • Flip the laptop over.
    • Remove the 6 mm screw with the Phillips #000 screwdriver.
  2. Samsung NP-QX411L Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Slide out the optical drive to remove it.
  3. Samsung NP-QX411L Battery Replacement, Hard Drive: 3 단계, 이미지 2개 중 1개 Samsung NP-QX411L Battery Replacement, Hard Drive: 3 단계, 이미지 2개 중 2개
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
  4. Samsung NP-QX411L Battery Replacement: 4 단계, 이미지 2개 중 1개 Samsung NP-QX411L Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
  5. Samsung NP-QX411L Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
  6. Samsung NP-QX411L Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
  7. Samsung NP-QX411L Battery Replacement, Battery: 7 단계, 이미지 1개 중 1개
    • Use the Phillips #000 screwdriver to remove the 6 mm screw.
  8. Samsung NP-QX411L Battery Replacement: 8 단계, 이미지 2개 중 1개 Samsung NP-QX411L Battery Replacement: 8 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the top two rubber stoppers by grasping them with the precision tweezers and pulling up.
  9. Samsung NP-QX411L Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Remove nine 6mm cover screws using the Phillips #000 screwdriver.
  10. Samsung NP-QX411L Battery Replacement: 10 단계, 이미지 3개 중 1개 Samsung NP-QX411L Battery Replacement: 10 단계, 이미지 3개 중 2개 Samsung NP-QX411L Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Wedge the spudger under the cover and run it along the edges.
    • Pry the cover up with the spudger to remove it.
  11. Samsung NP-QX411L Battery Replacement: 11 단계, 이미지 2개 중 1개 Samsung NP-QX411L Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the four 3 mm screws using the Phillips #000 screwdriver.
  12. Samsung NP-QX411L Battery Replacement: 12 단계, 이미지 1개 중 1개
    • A wire is still connecting the battery to the motherboard.
    • Lift and slide the battery out from under the three plastic prongs.
  13. Samsung NP-QX411L Battery Replacement: 13 단계, 이미지 1개 중 1개
    • Grab the wires and gently pull them away from the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Rebecca Johnson
회원 가입일: 02/17/17
594 평판
안내서 5개를 작성함
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G3
4 회원들
안내서 5개를 작성함
1가이드 댓글
Pardon the interruption, but do you potentially have a tutorial on how to replace the keyboard on this laptop? I am having problems finding an acceptable-enough tutorial on how to do it, yet I need such a tutorial as the process seems quite daunting.
Thanks,
Random Person on the Internet
Anonymous Schmuck - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 51
전체 시간: 4,424
