주요 콘텐츠로 건너뛰기
Samsung NP-QX411L Hard Drive Replacement
필요한 것
  1. Samsung NP-QX411L Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Samsung NP-QX411L Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Put on the anti-static wristband and connect the attached alligator clip to a metal object. This will prevent you from shocking the motherboard.
    • Flip the laptop.
    • Use the Phillips #000 screwdriver to unscrew the 6 mm screw from the square panel.
  2. Samsung NP-QX411L Hard Drive Replacement: 2 단계, 이미지 1/2 Samsung NP-QX411L Hard Drive Replacement: 2 단계, 이미지 2/2
    • Gently wedge the spudger under the square panel.
    • Run the spudger under the edges of the square panel to loosen it.
    • Remove the panel.
  3. Samsung NP-QX411L Hard Drive Replacement: 3 단계, 이미지 1/1
    • Remove the hard drive slowly because it is still connected to a wire.
    • Pull up on the rubber flap or use the spudger to lift the hard drive.
  4. Samsung NP-QX411L Hard Drive Replacement: 4 단계, 이미지 1/1
    • Remove the hard drive by gently pulling the power connector at the base of the wire off. You can do this by pulling the connector away from the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Rebecca Johnson
회원 가입일: 02/17/17
561 평판
안내서 5개 작성하였습니다
USF Tampa, Team S19-G3, Hoffman Spring 2017 USF Tampa, Team S19-G3, Hoffman Spring 2017 회원
USFT-HOFFMAN-S17S19G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 20
전체 시간: 1,510
