주요 콘텐츠로 건너뛰기
Samsung NP-R540-JA09US Hard Drive Replacement
필요한 것
  1. Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Samsung NP-R540-JA09US Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Flip the device to the bottoms-up position and locate the panel that says HDD.
    • In case of damage to panel, the HDD panel is just immediately right of the optical drive, and opposite from the battery
  2. Samsung NP-R540-JA09US Hard Drive Replacement: 2 단계, 이미지 1/3 Samsung NP-R540-JA09US Hard Drive Replacement: 2 단계, 이미지 2/3 Samsung NP-R540-JA09US Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the two 3.7mm securing screws with a Phillips #0 screwdriver.
    • After removing the screws, remove the panel covering the HDD.
  3. Samsung NP-R540-JA09US Hard Drive Replacement: 3 단계, 이미지 1/3 Samsung NP-R540-JA09US Hard Drive Replacement: 3 단계, 이미지 2/3 Samsung NP-R540-JA09US Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the screws on the bracket and then remove the bracket by pulling up.
    • Once the bracket has been removed, slide the hard drive towards the gap in the cavity and then remove it from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Conner Patterson
회원 가입일: 09/21/18
381 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 959
