주요 콘텐츠로 건너뛰기
Samsung NP-R540-JA09US RAM Replacement
필요한 것
  1. Samsung NP-R540-JA09US RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. Samsung NP-R540-JA09US RAM Replacement: 2 단계, 이미지 1/1
    • Pull the two latches outward.
  3. Samsung NP-R540-JA09US RAM Replacement: 3 단계, 이미지 1/2 Samsung NP-R540-JA09US RAM Replacement: 3 단계, 이미지 2/2
    • Slide the battery out of the laptop.
  4. Samsung NP-R540-JA09US RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Unscrew and remove the two screws from the back panel labeled "Memory" with a Phillips #0 screwdriver.
  5. Samsung NP-R540-JA09US RAM Replacement: 5 단계, 이미지 1/1
    • Place the flat end of the spudger or your fingers, if possible, between the panel and the laptop. Pry the panel by moving the spudger up and down until the panel can be removed.
  6. Samsung NP-R540-JA09US RAM Replacement: 6 단계, 이미지 1/2 Samsung NP-R540-JA09US RAM Replacement: 6 단계, 이미지 2/2
    • Release the two holding pins by pushing them away from each other with your fingers or a spudger.
  7. Samsung NP-R540-JA09US RAM Replacement: 7 단계, 이미지 1/1
    • Pull the RAM out of the laptop with your fingers by gently lifting it up.
결론
Conner Patterson
회원 가입일: 09/21/18
381 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 562
