주요 콘텐츠로 건너뛰기
Samsung NP270E5E-K03US Hard Drive Replacement
필요한 것
  1. Samsung NP270E5E-K03US Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Samsung NP270E5E-K03US Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Hard Drive Replacement: 2 단계, 이미지 1/2 Samsung NP270E5E-K03US Hard Drive Replacement: 2 단계, 이미지 2/2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Samsung NP270E5E-K03US Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Hard Drive Replacement: 4 단계, 이미지 1/2 Samsung NP270E5E-K03US Hard Drive Replacement: 4 단계, 이미지 2/2
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Hard Drive Replacement: 5 단계, 이미지 1/2 Samsung NP270E5E-K03US Hard Drive Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kyle Golden
회원 가입일: 03/23/17
353 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S9-G1, Martin Spring 2017 UMass Dartmouth, Team S9-G1, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 1,698
