주요 콘텐츠로 건너뛰기
Samsung NP270E5E-K03US Internal Fan Replacement
필요한 것
  1. Samsung NP270E5E-K03US Internal Fan Replacement, Battery: 1 단계, 이미지 1/2 Samsung NP270E5E-K03US Internal Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US Internal Fan Replacement: 2 단계, 이미지 1/2 Samsung NP270E5E-K03US Internal Fan Replacement: 2 단계, 이미지 2/2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: 3 단계, 이미지 1/3 Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: 3 단계, 이미지 2/3 Samsung NP270E5E-K03US Internal Fan Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
  4. Samsung NP270E5E-K03US Internal Fan Replacement: 4 단계, 이미지 1/2 Samsung NP270E5E-K03US Internal Fan Replacement: 4 단계, 이미지 2/2
    • Locate the gray hard drive cover, and remove the four corner 3.5mm screws.
  5. Samsung NP270E5E-K03US Internal Fan Replacement: 5 단계, 이미지 1/2 Samsung NP270E5E-K03US Internal Fan Replacement: 5 단계, 이미지 2/2
    • Lift the hard drive cover by pulling upwards on the removal handle.
    • You can now remove the hard drive from the laptops housing freeing up space to replace your damaged or broken hard drive with a new hard drive.
  6. Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: 6 단계, 이미지 1/3 Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: 6 단계, 이미지 2/3 Samsung NP270E5E-K03US Internal Fan Replacement, Internal Fan: 6 단계, 이미지 3/3
    • A single 4 mm hidden screw is located under the rubber grip pad in the top right corner. With the Phillips screw driver, remove the grip pad by popping it out of its space.
    • Remove all seventeen 4 mm screws from the back panel marked in the image.
    • Be careful not to tear the rubber foot hiding the screw.
  7. Samsung NP270E5E-K03US Internal Fan Replacement: 7 단계, 이미지 1/3 Samsung NP270E5E-K03US Internal Fan Replacement: 7 단계, 이미지 2/3 Samsung NP270E5E-K03US Internal Fan Replacement: 7 단계, 이미지 3/3
    • Use an opening tool to pop out the back panel from the laptop. Start at the back corners shimmy the opening tool around all edges of laptop before the panel comes loose.
    • This is a slow process, do not attempt to force the entire panel open before making sure you have pried the edges around the entire laptop.
  8. Samsung NP270E5E-K03US Internal Fan Replacement: 8 단계, 이미지 1/3 Samsung NP270E5E-K03US Internal Fan Replacement: 8 단계, 이미지 2/3 Samsung NP270E5E-K03US Internal Fan Replacement: 8 단계, 이미지 3/3
    • Take off the back panel and move it away from the work space.
    • Remove the two 4 mm screws holding the fan in place.
    • Make sure you are keeping all of the screws gathered in a safe place where they will not get lost.
  9. Samsung NP270E5E-K03US Internal Fan Replacement: 9 단계, 이미지 1/3 Samsung NP270E5E-K03US Internal Fan Replacement: 9 단계, 이미지 2/3 Samsung NP270E5E-K03US Internal Fan Replacement: 9 단계, 이미지 3/3
    • Locate the white cable connecting the fan to the motherboard. Unclip the cable from the motherboard.
    • The fan is now free from the laptop and can be wiggled free / removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 03/21/17
177 평판
안내서 1개 작성함
UMass Dartmouth, Team S9-G1, Martin Spring 2017 UMass Dartmouth, Team S9-G1, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 1,267
