소개
In this guide you will learn how to remove the entire back side of the laptop in order to access and replace a damaged or broken internal fan.
필요한 것
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
Unscrew the 4mm screw, and slide the cover off away from the computer to reveal the housing for the hard drive and RAM boards.
A single 4 mm hidden screw is located under the rubber grip pad in the top right corner. With the Phillips screw driver, remove the grip pad by popping it out of its space.
Remove all seventeen 4 mm screws from the back panel marked in the image.
다른 한 분이 해당 안내서를 완성하였습니다.
