주요 콘텐츠로 건너뛰기
Samsung NP270E5E-K03US RAM Replacement
필요한 것
  1. Samsung NP270E5E-K03US RAM Replacement, Battery: 1 단계, 이미지 1/2 Samsung NP270E5E-K03US RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Begin with the laptop lying to its back revealing its underside.
    • Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
  2. Samsung NP270E5E-K03US RAM Replacement: 2 단계, 이미지 1/2 Samsung NP270E5E-K03US RAM Replacement: 2 단계, 이미지 2/2
    • Completely remove the battery from the laptop.
  3. Samsung NP270E5E-K03US RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Remove the 4mm screw with a Phillips #0 screwdriver.
  4. Samsung NP270E5E-K03US RAM Replacement: 4 단계, 이미지 1/3 Samsung NP270E5E-K03US RAM Replacement: 4 단계, 이미지 2/3 Samsung NP270E5E-K03US RAM Replacement: 4 단계, 이미지 3/3
    • Once the screw holding the cover down has been removed the cover can then be removed by sliding the cover in the direction of the gray arrow on the laptop.
    • The cover can then be removed to reveal the laptops RAM boards and also the laptops hard drive.
  5. Samsung NP270E5E-K03US RAM Replacement: 5 단계, 이미지 1/3 Samsung NP270E5E-K03US RAM Replacement: 5 단계, 이미지 2/3 Samsung NP270E5E-K03US RAM Replacement: 5 단계, 이미지 3/3
    • The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
    • To disengage the latches you must push them gently outwards until a soft click is heard.
    • If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
  6. Samsung NP270E5E-K03US RAM Replacement: 6 단계, 이미지 1/1
    • You can now pull the RAM board from the housing freeing up space for your new replacement RAM board.
    • Do not try to remove the RAM before the latches have disengaged and the RAM has popped up, otherwise risk damaging the computer / components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Golden
회원 가입일: 03/23/17
353 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S9-G1, Martin Spring 2017 UMass Dartmouth, Team S9-G1, Martin Spring 2017 회원
UMASSD-MARTIN-S17S9G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 18
전체 시간: 1,080
