소개
If you find that your Samsung ATIV Book 2 has begun to operate slowly or is having issues with blue screens it may be time to replace the RAM. In this guide you will learn to do so.
필요한 것
Begin with the laptop lying to its back revealing its underside.
Locate the two latches on the bottom of the laptop. Slide the latches inward until a faint click is heard.
The RAM boards are each held in place by a pair of spring latches (indicated by red circles) which must be disengaged.
To disengage the latches you must push them gently outwards until a soft click is heard.
If you are successful in disengaging the latches the RAM board will pop upwards allowing for easy removal.
다른 한 분이 해당 안내서를 완성하였습니다.
