주요 콘텐츠로 건너뛰기
Samsung NP300E5C Hard Drive Replacement
필요한 것
  1. Samsung NP300E5C Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Hard Drive Replacement: 2 단계, 이미지 1/3 Samsung NP300E5C Hard Drive Replacement: 2 단계, 이미지 2/3 Samsung NP300E5C Hard Drive Replacement: 2 단계, 이미지 3/3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: 3 단계, 이미지 2/3 Samsung NP300E5C Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3/3
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
    • Firmly, but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  4. Samsung NP300E5C Hard Drive Replacement: 4 단계, 이미지 1/3 Samsung NP300E5C Hard Drive Replacement: 4 단계, 이미지 2/3 Samsung NP300E5C Hard Drive Replacement: 4 단계, 이미지 3/3
    • Remove these four 4 mm Phillips #8 screws using a Phillips #00 screwdriver.
    • Gently lift the hard drive up, however do not remove it.
  5. Samsung NP300E5C Hard Drive Replacement: 5 단계, 이미지 1/2 Samsung NP300E5C Hard Drive Replacement: 5 단계, 이미지 2/2
    • Firmly grasp the base of the connector at the bottom of the hard drive.
    • Gently pull the connector off to free the hard drive.
결론
다른 11명이 해당 안내서를 완성하였습니다.
aliahsan95
회원 가입일: 09/23/15
937 평판
안내서 4개 작성하였습니다
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G13
3 회원들
안내서 4개 작성하였습니다
댓글 2개
I want to change this HDD with a SSD drive. How do I know which drive to look for? Do i need some kind of adapter or i just have to plug it?
johnetix - 답글
The HDD is connected using Serial ATA (SATA) and most modern SSD drives will also use a SATA connection. You will be able to install the new drive without any adapters.
Oscar B -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 32
전체 시간: 12,344
