주요 콘텐츠로 건너뛰기
Samsung NP300E5C Optical Drive Replacement
필요한 것
  1. Samsung NP300E5C Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Lay laptop down so that the bottom is facing the sky.
  2. Samsung NP300E5C Optical Drive Replacement: 2 단계, 이미지 1/3 Samsung NP300E5C Optical Drive Replacement: 2 단계, 이미지 2/3 Samsung NP300E5C Optical Drive Replacement: 2 단계, 이미지 3/3
    • Push both tabs away from the center of the device.
    • While both are in the fully unlocked position, slide the battery out.
  3. Samsung NP300E5C Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/1
    • Remove this 4 mm Phillips #8 screw using a Phillips #00 screwdriver.
  4. Samsung NP300E5C Optical Drive Replacement: 4 단계, 이미지 1/2 Samsung NP300E5C Optical Drive Replacement: 4 단계, 이미지 2/2
    • With the 4 mm Phillips #8 screw removed, firmly but gently pull the cover towards you.
    • After moving the cover about 2 centimeters, you can lift and remove it.
  5. Samsung NP300E5C Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove the 4 mm Phillips #8 screw to the left of the hard drive using a Phillips #00 screwdriver.
  6. Samsung NP300E5C Optical Drive Replacement: 6 단계, 이미지 1/2 Samsung NP300E5C Optical Drive Replacement: 6 단계, 이미지 2/2
    • Using your fingernail or spudger to gently pull your optical drive out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
aliahsan95
회원 가입일: 09/23/15
937 평판
안내서 4개 작성하였습니다
Baylor, Team 10-13, Williams Fall 2015 Baylor, Team 10-13, Williams Fall 2015 회원
BU-WILLIAMS-F15S10G13
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Great video, simple steps to follow, very good, thanks.
Chris Hughes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 2,181
